BCU swap
Old Jul 1, 2012 | 10:31 AM
otanovision's Avatar
Default BCU swap
The problems:
Front windows don't work and the engine is massively misfiring. According to the RAVE and some help here. This is likely attributed to a bad BCU. I went to a junk yard and yanked a same year (2002) unit.
Is it possible to simply swap BCU boxes with out consequence? To put it another way, is is Plug and play?
Old Jul 1, 2012 | 11:22 AM
b c u is not part of misfire
Old Jul 1, 2012 | 11:23 AM
jafir's Avatar
Yeah, what he said. BCU stands for Body Control Unit, and doesn't do much with the engine.
Old Jul 1, 2012 | 02:34 PM
tee51397's Avatar
No, not p&p.
Old Jul 1, 2012 | 02:45 PM
wilson96rr's Avatar
you have to get it programed to your ecu and guages, etc.
Old Jul 1, 2012 | 03:14 PM
I would not swap it out till you find your mis-fire issue, what fault code numbers do you have?
And if you swap out the BCU, as already mentioned, it won't fix the mis-fire and you will not be able to start the engine until re-programed.
Old Jul 2, 2012 | 08:28 AM
Copy that. I'll retrieve the codes-after I buy a code reader. Any recommendations on a good (read inexpensive) one?
Old Jul 2, 2012 | 08:35 AM
ZGPhoto's Avatar
Go get the codes read at a local car parts place. Misfires are usually a coil pack, plug, or wire issue. I would guess coils though..
Old Jul 2, 2012 | 01:37 PM
hilltoppersx's Avatar
i disagree with this.
get the codes read, you are more likely having a problem with the wires or maf.
Old May 31, 2014 | 12:49 PM
Josh Matthew's Avatar
7th Gear
Would you have to have it reprogrammed if you replaced both the ECU and the BCU?
