Bearing replacement
Old Dec 8, 2009 | 11:01 PM
DooDer's Avatar
Default Bearing replacement
I'm looking to replace both sets of bearings in my '04 Discovery but I'm curious if I can replace the main bearings without removing the crankshaft from the block. Is there a way to simply slip the main bearings into place?
If not, I assume that I have to somehow be able to seperate the engine from the transmission enough to be able to get to the flywheel and remove it thus releasing the crank. Do I have to drop the tranny to do this?
Thanks!
RoverMasterTech
Mar 26, 2016 01:57 PM
Grlica
May 1, 2013 06:13 PM
RoverMasterTech
Mar 16, 2012 12:07 PM
zracin
Mar 23, 2008 09:26 AM
