Bearmach Regulator
Old Sep 14, 2021 | 11:30 AM
redrover75's Avatar
Default Bearmach Regulator
So, I bought a bearmach CUR100440 to replace a dead window motor. The wiring harness are different. Before I cut it open, does anyone know the correct wiring diagram? Top is the truck, bottom is the new motor. I know I could trial and error, but with my luck the motor would be the wrong part.
stock connector
Bearmach connector
Old Sep 14, 2021 | 11:53 AM
acg's Avatar
acg
I am also working on my window regulator. The new motor has the same plug as the plug inside the door.
Old Sep 14, 2021 | 11:59 AM
Best4x4's Avatar
You do not unplug the lead from the motor itself. The plug should be tucked up inside the door and held in place via a plastic clip. That plug should match the new motor.
Old Sep 14, 2021 | 02:30 PM
redrover75's Avatar
great, thank you. will take a look.
redrover75
Sep 8, 2021 07:15 AM
LADisco2
Mar 10, 2021 04:50 PM
jasonRedRover
Aug 4, 2016 09:03 PM
Jwhitfie
Dec 11, 2015 11:35 PM
RedAustinIX
Aug 29, 2010 03:11 AM
