Bearmack t- stat
Old Feb 29, 2020 | 09:47 AM
leungp's Avatar
6th Gear
Mine runs between 195 - 200 during a 72-degree winter in HK.
Bought a 182-degree t-stat and ready to run it cooler to prevent blowing the vulnerable head gasket.
Old Feb 29, 2020 | 10:32 AM
redwhitekat's Avatar
i think you already have a 180 degree.
If you had the oem you would be in the 210-225 range
Old Feb 29, 2020 | 07:17 PM
leungp's Avatar
6th Gear
Is that right?
Coolant temp. doesn't drop below 195 on motorway. I thought it'd drop below 190 on high speed.
Old Feb 29, 2020 | 08:22 PM
Is that right?
ya mine are usually 195-198 on the highway
when I had the oem it was going into the 210-215
Old Feb 29, 2020 | 10:36 PM
Dave03S's Avatar
A normal 180 stat will run 188.5 on the freeway around 70 mph other than hills.
An improper or incomplete bleed of the cooling system will yield a 10 degree variance on the high side.
Old Mar 1, 2020 | 12:25 AM
i never run that low in any condition with my warm weather thermostat 180
Old Mar 5, 2020 | 08:56 PM
Got my new expansion tank and this thermostat installed stamped 78 c
now runs 188 on the freeway and idles 195-203
not bad Only difference between this thermostat and my warm weather 180 is when your moving it drops to 188 instead of the usual 197
samroy92
Mar 7, 2020 05:35 PM
chasen7
Jun 22, 2016 11:15 PM
Motorhead1
May 19, 2016 08:28 PM
hankeester
May 21, 2014 09:40 AM
redwhitekat
Dec 12, 2012 12:08 PM
