belt change
Old Dec 20, 2008 | 06:54 PM
sloppyjoe's Avatar
Default belt change
when i was under the hood this morning i noticed the serp. belt was looking a little shiny and the grooves were a bit tattered.
whats the normal procedure for swapping the belt?
Old Dec 20, 2008 | 07:06 PM
Default RE: belt change
Loosen the belt tensioner, remove belt, replacement is reversale of removal.
Nothing to remove except the belt.
Make sure that the new belt is routed properly, very easy to goof up but still have it look right.
Old Dec 20, 2008 | 07:08 PM
sloppyjoe's Avatar
ORIGINAL: Spike555
i figured that was all there was too it, but it is after all a LR
Old Dec 20, 2008 | 07:11 PM
It is pretty straight forward, you could make it more difficult if you want to.
Remove the water pump first, then the belt.
Old Dec 20, 2008 | 07:15 PM
Night Train's Avatar
It's a 15mm socket for the tensioner...I used a 3/4" drive ratchet, depending on strength a breaker bar could be required. Bring just enough tension off the belt with one hand and slide it out with the other...if you over crank the tensioner, oops new one required. Once the belt is off, the tension will have the ratchet against the battery box... no big deal, I held (by hand) the tensioner and removed the ratchet to allow the tensioner to seek home to ensure it applies proper tension on the new belt (sloppy tension = sloppy belt).
easy took 15 minutes
enjoy
Robert
Old Dec 20, 2008 | 07:27 PM
sloppyjoe's Avatar
indeed!
Old Dec 20, 2008 | 07:37 PM
phatduc's Avatar
Thx for the tip! I started in on this job inorder to swap out a blown PS pump, then got in over my head...
SO I Just got done burning the Rave CD for the D2. Holy smokes what a treasure trove of info. I had NO IDEA.
________
PAXIL SETTLEMENT INFORMATION
collin Barrows
Aug 28, 2011 07:13 AM
TheUninformedOwner
Freelander
Apr 15, 2009 08:25 PM
mr_boondoggle
Freelander
Apr 14, 2009 01:11 PM
christians1600
May 6, 2008 09:21 AM
Robeye
Feb 28, 2008 11:32 AM
