Belt noise after massive coolant leak & repair...
OK. Got shorter belt since it turns out I don't have ACE. Changed it, and no problems since. Maybe the belt just slipped real bad on the alternator causing the car to think it needed "limp mode"? Who knows...
Anyway, seems fixed, for now. Gimme 2 more weeks. I'm sure I'll have another problem.
IMHO you might want to get battery tested at one of the parts stores. If alternator belt was slipping, not charging enough, so much that the tranny ECU detected this and decided to limp home, your existing battery may be starting to have problems (or dirty connectors). Usually they do the test for free with a small machine, battery stays in the car.
