Best path for routing wires from dash to battery?
Old Dec 19, 2015 | 06:21 AM
batard's Avatar
Default Best path for routing wires from dash to battery?
After installing a new amp, I've come to find out that the stock power wire and ground aren't sufficiently large for the kind of power the amp puts out. So I need to replace them with one wire that goes directly from the amp to the battery and another that goes to chassis ground. I'll put a 15A inline fuse on the wire near the battery for protection, since I'll be bypassing the interior and engine compartment fuse boxes through which the stock wires pass.
What's the best, least disruptive way to route wires like this? It's not 100% clear to me where the stock wiring comes through, though I guess it must be coming out around where the coils are and then through the engine harnesses to the battery. I'm not in the mood to take off the intake manifold to route one wire, though. I don't have a heater core (I live in a desert environment). Could I route the wiring through the heater core pipes that go through the firewall? Could/should I just drill a hole in the firewall along the passenger's side and run it to the battery that way?
Any suggestions/advice much appreciated.
Old Dec 19, 2015 | 07:15 AM
Alex_M's Avatar
I'll get some Pictures of my routing for you in a little bit.
Old Dec 19, 2015 | 07:57 AM
batard's Avatar
Excellent – would love to see that.
Old Dec 20, 2015 | 12:04 PM
Alex_M's Avatar
Completely forgot to get pictures. I'm setting a reminder on my phone to get them when I'm home this evening.
Old Dec 20, 2015 | 02:18 PM
batard's Avatar
No worries. I'm not planning on doing this for a few days at least, in any case.
Old Dec 20, 2015 | 03:19 PM
Charlie_V's Avatar
I drilled a hole next to the main harness pass through on the passenger firewall, then used a grommet to protect the wires. You just have to eyeball the distance and location, looking up from the passenger footwell.
The other openings are sealed. But if water gets that high on mine I'm screwed anyway.
Old Dec 20, 2015 | 07:30 PM
Alex_M's Avatar
Here's the picture! As you can see, I routed it between the fuse box and the coolant overflow then back to the firewall grommet. I cut a little slit in it with a box cutter and ran the cables right through.
Old Dec 21, 2015 | 07:38 AM
batard's Avatar
This is brilliant, thanks for the pic. Seems like the place to go.
adolfojbonilla
Nov 2, 2015 08:05 PM
SinisterMoose
Jun 16, 2015 04:26 PM
Savannah Buzz
Off Topic
May 17, 2012 04:34 PM
rj95lss
Jan 26, 2010 11:07 AM
discoxd
Dec 30, 2008 04:43 PM
