Best results for clouded headlights?
Old Jan 25, 2019 | 11:01 AM
bcurtman's Avatar
Default Best results for clouded headlights?
I used some headlight restorer and they improved, but not like I want them. Can I hit them with my orbital buffer? What is the best solution aside from buying new ones? Anyone have a secret sauce?
Old Jan 25, 2019 | 11:03 AM
CollieRover's Avatar
When you have them to an acceptable appearance spray then with UV Resistant Clearcoat.
Old Jan 25, 2019 | 01:33 PM
Big Jim Swade's Avatar
I've tried polishes and other headlight restorer kits on other vehicles and none of them had very good results. Replacing headlights is expensive, but the only thing that really works.
Old Jan 25, 2019 | 02:42 PM
I found a youtube video on wetsanding, and it worked pretty well.
Old Jan 25, 2019 | 02:58 PM
gulfdisco's Avatar
wet sand 1000 then 1500 variable speed polisher with 3m machine polish. Did both my D2's like this.
Old Jan 25, 2019 | 04:06 PM
earlyrover's Avatar
Default headlight clear plastic polishing
You can buy a clear plastic polish, sold for plastic aquariums, some which are huge, several hundred gallons, so big plastic, that work well. Or, as a final super fine polish, you can simply use tooth paste and a lot of elbow grease.
Old Jan 25, 2019 | 06:43 PM
Twix's Avatar
I've always wet sanded. Start with 800 or 1000, and work up to 3000. Then as mentioned above, spray with a UV coating
Old Jan 26, 2019 | 02:45 PM
Friday Night Disco's Avatar
I always use Mother's headlight restorer that you can pick up at local auto part storre. The stuff has never failed, oh having a cordless drill will help with the buffing.
Old Jan 26, 2019 | 03:17 PM
Dave03S's Avatar
I've had good luck with the Mothers product as well...
Old Jan 26, 2019 | 05:00 PM
Bulax99's Avatar
I’ve used this and it is by far the best stuff I have ever used. No need to sand if you are using a buffer and 3” pads. They have it for sale too. TP-3 is the code for it. Micropad buffing kit. It has all the adapters you need to use it with a high speed buffer or drill.
https://www.autobeautyproducts.com/product/A001.html
09dewaed
Dec 4, 2017 06:36 PM
Eurobahn LandRover
Detailing
Jan 18, 2016 04:00 PM
slabrat
Detailing
Sep 26, 2013 12:16 PM
Xrover
Detailing
May 18, 2013 08:06 AM
Disco03
Dec 1, 2008 08:08 PM
