Best source for alternator these days
Old Apr 7, 2019 | 09:39 AM
Ben Matheson's Avatar
Default Best source for alternator these days
I'm running 13.3 volts if I run front and rear AC units. Seems to be heat related. Cold engine output is good but once everything is warmed up under the hood the output drops dramatically
Old Apr 7, 2019 | 09:53 AM
redwhitekat's Avatar
13.3 volts seems ok to me
whats the issue ??
Old Apr 7, 2019 | 10:01 AM
whats the issue ??
Should be 13.8 minimum. I noticed the transmission isn't happy with the voltage that low.
Old Apr 7, 2019 | 10:14 AM
Lisa Bunch's Avatar
Find a local company that rebuilds them using high quality parts, like semi truck drivers use. Seriously. You will have a better product for the money. If you have to , get one from a wrecking yard and take it to a reputable rebuilder.
Old Apr 7, 2019 | 11:04 AM
Jeff Blake's Avatar
I bought a "200 amp" rebuilt alternator off eBay about 2 years ago. Runs at 14v. Seems to be working ok, the only issue, that I'm not sure is an issue, is when I run a heavy load like my dual compressors (~50A), the voltage drops to under 12.6 which leads me to believe it can't push out anywhere near 200 amps. I think if I did this again I would consider a genuine bosch brand new 150A alternator (from the P38)
Old Apr 7, 2019 | 11:25 AM
bcurtman's Avatar
I just replaced my worlds oiliest alternator with an ac Delco from rock auto. It was reasonable and I'll get $60 back for the core. Doesn't come with the pulley, but an easy swap.
Old Apr 7, 2019 | 11:37 AM
Best4x4's Avatar
Parts Player P38 Bosch RR 150AMP is the way to go. I wouldn't bother with a D2 120 Valeo or 130 Bosch alternator when you can get the P38 99-02 150AMP unit for around 134.00 online either thru Amazon or Ebay.
JPSpen
Feb 25, 2013 05:53 PM
Dean
Aug 15, 2012 07:06 PM
DustyLBottoms
Nov 24, 2011 05:06 PM
GLOCK3462
Oct 17, 2011 12:36 PM
matrixclese
May 30, 2010 03:09 PM
