Best Upgrade Path?
Best Upgrade Path?
So my end goal is to make my truck look kinda like these guys:
Rover Example Trucks - Album on Imgur
I have a 2003, stock except for with what I believe is a heavy duty OME lift. Parts are:
Front Shock: OME Nitrocharger 60024
Rear Shock: OME 60025
Front Spring: OME779 - Extra Heavy Duty
Rear Spring: OME762 - Heavy Duty
My next purchase is going to be a 2004 CDL from a local junkyard (~$300). What I'd like to figure out is what order I should buy all the next items so that eventually I can run 33's and maybe eventually 35's.
What I have is the following:
ARB Lockers w/4.10 gears - ($3096.00) - Lucky8 Llc. - Take the road less traveled...
ARB Air Compressor - ($276.00) - https://www.expeditionexchange.com/c...cat=265&page=1
Ashcroft HD axles - ($1,520.00) - Lucky8 Llc. - Take the road less traveled...
1" Spring Spacers - ($130.00) - Lucky8 Llc. - Take the road less traveled...
OK Offroad Wheels - ($559.00) - OKoffroad.com Stuff - Xtreme Duty Land Rover Wheels
BF Goodrich KO2 285/75R16 (32.9") - ($989.25) - BF Goodrich Tires - LT285/75R16, All-Terrain T/A KO2 | 4WheelParts.com
Flexi Fender Flares - ($321.00) - Lucky8 Llc. - Take the road less traveled...
I also plan on buying a welder (hobart) and crafting my own bumpers and rock sliders, maybe some skid and diff guards as well.
As far as what I am planning on doing with my truck, it is mostly for camping off forest service roads here in Colorado. A little light wheeling, I probably won't try anything that has a Trail Damage rating over 5. I know this stuff might seem overkill for what I plan on doing, but I just want the truck to look a little ridiculous and generally just never get stuck.
Is there anything I'm missing to run 33's? What order would you install these upgrades? Is there anything that absolutely must be done before something else or at the same time? Anything unnecessary?
To be honest, I'd do Detroit lockers instead of ARB based on reliability according to people I've talked to. Here would be my order:
Spacers
Tires with either wider offset rims or 1.5-2" BORA wheel spacers if you'd prefer to keep stock rims. Just a matter of preference. L8 has the rims too, and may give a discount on that much stuff together. I don't want to say for sure, but work shooting Erik a message or giving them a call Monday.
Axles
Lockers and gears
Flares
Also, those Hobart welders are nice, but you can get a plenty suitable welder for a lot less if you wanted. I've got a Lotos Mig 140 I got from Amazon. I think they're around $380 unless they went up again. I've been through a couple spools of Flux and love it. Comes with a mask and wire brush as well as a few different tip sizes and everything you need to run gas for Mig. I'm relatively sure its the exact same welder as the Hobart. I know it uses the sake internals as some reputable brand.
Spacers
Axles
Lockers and gears
Flares
I would have to agree with those tires you will need to upgrade the diffs it a matter of choice but I would choose mechanical locker.
Spacers
Axles
Lockers and gears
Flares
Spacers
Axles
Lockers and gears
Flares
SinisterMoose
06-16-2015 04:26 PM
