Better 02 Sensors?
Old Feb 29, 2012 | 07:18 PM
urq's Avatar
urq
Default Better 02 Sensors?
Is there one brand that is better then another when it comes to 02 sensors?
The reason I ask is I got this car a few weeks ago with 2 new 02 sensors in the front after a few days I got a Code P0150 then I cleared it changed the air filter and inspected and cleaned the MAF then I got a Code P0154? after doing some reading I see you should change all four at the same time, does that mean the 2 fronts are trash now I mean there are less then 200 miles on them.
Also is there one brand better then another?
Old Feb 29, 2012 | 07:36 PM
DonRW2007's Avatar
Default I defer to others, but those sensors are O.K.
Best to replace all at once, I think, but having said that, it's not like the previously installed sensors are going to be damaged. I'd be more concerned about cleaning of the MAF, as that can cause issues.
Old Feb 29, 2012 | 09:00 PM
mx468's Avatar
I would use the bosch oem sensors, I've tried aftermarket cheaper ones and they worked like crap!!!!!! There are some things on a rover that I would stick to only original parts like 02 sensors and MAF's.
mlfore
Apr 8, 2008 03:38 PM
Brad S1
Aug 30, 2006 12:31 PM
Randy Lover
Off Topic
Jan 12, 2006 02:52 PM
dogstarsix75
Apr 23, 2005 11:21 AM
05LandRover
Off Topic
Feb 12, 2005 03:35 AM
