Big Plans This Weekend (Need Advice!)
looks mean, but is a total panzy. Husky/GSD mutt.
Fluid hand pump for filling the t-case and transmission. Creeper and ramps for scooting around underneath, unless it's on a lift.
You may need to purchase a 12-point 8mm 1/4" drive socket (or 3/8" drive deep socket) in order to do the rocker covers. It's an unusual piece of equipment, even for a well-stocked workshop.
jastutte (02-06-2021)
second the hand pump for the T-Case and Transmission.
If his friend has a "fully loaded shop" he more than likely has a fluid pump. Likely a better one than most of us make do with.
The only thing I would question about what you are doing is the tie rod end. The OE drag link and track bar are kind of flimsy, and if one tie rod end is bad (drag link) more than likely the other two are as well (track bar). When I discovered the tie rod ends on my truck were bad I bought and installed the heavy duty drag link and track bar replacements.
I got the tie rod end based on my buddies recommendation after he gave it a once over. I’ll ask about the track bars while we’re down there Monday and see what his opinion is.
thanks!
So far, so bad. Haha took the Valve covers off to find a complete mess of gunk and roasted oil. So far I’ve only successfully changed the diffs and t-case oil, put in the new spark plugs, replaced the air filter, and installed a PCV Valve while removing the old oil separator and flushing the tubes for Best4x4’s PCV mod recommendation.
I’ve scrubbed the valve covers themselves about as good as they’ll get, any tips on doing the rockers themselves? Preferably one that doesn’t require removal and retiming.
I agree with mollusc. Just remove the rocker arms and get them cleaned up off the engine. Maybe your friend with the garage has a good parts cleaning setup.
Just keep track of which side each rocker arm came from. They are identical when manufactured, but I would recommend putting them back on the side they came from. Same with the pushrods. I drill holes In a 2 x 4 to keep the pushrods in order.
