BIG PROBLEM PLEASE HELP
Old 01-24-2009, 11:57 AM
lrd2's Avatar
Default RE: BIG PROBLEM PLEASE HELP
how do i know if i have a ace system?
  #22
Old 01-24-2009, 12:05 PM
Disco2Guy's Avatar
Ok, the fuel filter is in the gas tank of the D2. Usually D1 owners need to replace it. For the ACE, look at you power steering tank. Does it have one or two caps on it? Two caps means you have ACE.
  #23
Old 01-24-2009, 06:22 PM
lrd2's Avatar
1 cap
  #24
Old 01-24-2009, 07:37 PM
Your radiator hose came off because of age, hoses and clamps go bad over time. Replace ALL hoses and clamps every 5 years no matter the miles.
You are loosing coolant, you probally have a bad headgasket and it let compression gases into the cooling system and over pressurized it blowing the hose off because of a weak clamp.
  #25
Old 01-24-2009, 07:59 PM
EVN137's Avatar
opps sorry, on wrong thread
  #26
Old 01-24-2009, 09:01 PM
lrd2's Avatar
i am going to order the full hose kit from roverparts.com am also going to bleed the system and add new coolant what do you guys think should i replace the thermostat?
  #27
Old 01-24-2009, 09:04 PM
llPANCHOll's Avatar
Hell yes.. if you are going through the trouble of doing all that..
For the love of god.. finish the job..
You want to rule out all the possiblities,
If its still using fluid after that..
You will need to look at the Head Gaskets
Like mike said..
Try snugging up the bolts on the valve cover
  #28
Old 01-24-2009, 09:05 PM
lrd2's Avatar
also what do you guys think about the oil leak how hard is it to change the valve cover gasket?
  #29
Old 01-24-2009, 09:16 PM
lrd2's Avatar
ORIGINAL: Spike555
Spike how can i check if i have a bad headgasket?
  #30
Old 01-24-2009, 09:26 PM
lrd2's Avatar
am buying the complete hose kit from roverparts.com but not sure if the come with clamps should i order clamps?
Quick Reply: BIG PROBLEM PLEASE HELP
