BIG Tranny problem
Old Feb 13, 2007 | 09:14 PM
sm3earl's Avatar
7th Gear
Default BIG Tranny problem
hey everyone, i have a 1997 land rover and one night i was shifting to reverse from park and now the tranny only works in 1st and reverse.
Anyone know what could of happened?
Thanks in advance
-shawn
Old Feb 14, 2007 | 11:37 AM
Default RE: BIG Tranny problem
Can't tell you for sure what happened, probably the only way to tell will be to pull it down and open her up. At that point you will need to shop around and see what will be cheaper for you, rebuilding or replacing it.
Good luck and let us know what you find.
Mike
Old Feb 14, 2007 | 10:25 PM
piotrsuw's Avatar
Provided that the transmission worked completely fine before, and this happened all of a sudden:
This is likely asticky valve in the valve body. A sticky valve can be resolved without pulling the transmission - you (or your trusted repair shop) can pull the transmission pan off and pull the valve body out through the bottom. The valve bodiescan sometimes be ultrasonically cleaned or the valve body itselfcan be rebuilt with new seals, etc.Transmission shops usually know what to do with these. The valve body is at the bottom of the transmission and through a series of valves controls where the pressurized ATF is sent to. The pressurized ATF in turn locks you into a given gear. If one or more gears fail all of a sudden, or are intermitten, then a sticky valve would be suspect.
Piotr
Old Feb 15, 2007 | 11:58 AM
When I answered you the first time I thought you had a 5 speed, my error.
So I agree with the last post, try changing out your fluid, add a bottle of Lucas tranny additive and see if it will free up your valves or solemoids that may be sticking.
Mike
Old Feb 15, 2007 | 12:16 PM
sm3earl's Avatar
7th Gear
alright, thanks alot! ill try that later today.
-shawn
Old Feb 15, 2007 | 12:23 PM
Aquaholic's Avatar
If it fixes it I would change the fluid and filter again quickly.
New fluid has detergents that will break loose a lot of deposits...so it will work great for a while and then clog/break from all the stuff floating around.
Old Feb 15, 2007 | 12:26 PM
sm3earl's Avatar
7th Gear
ok thanks for the help. i will try all this later today.
-shawn
tgwaldop
Mar 16, 2011 07:26 AM
lrd2
Jan 25, 2009 09:22 AM
jg2003
Jan 10, 2009 09:56 PM
Bene
Oct 26, 2005 11:17 PM
kfordric
Aug 31, 2005 08:17 AM
