Bilstein?
Old Oct 5, 2007 | 02:17 AM
beachpugx1's Avatar
7th Gear
Default Bilstein?
I recently got a 200 Discovery which, so far, only has a couple obvious problems. The sunroofs leak like God trying to put out Satans fires. Second, when the off road height is up...all is good, when it is down, the back passenger side sometimes sits lower than the rest. I can't pinpoint it because sometimes it stays normal, sometimes it goes down. Anyone one know about Bilstein shocks? I'm thinking about using them and would this possibly fix my problem?
Old Oct 5, 2007 | 07:35 AM
Default RE: Bilstein?
Are you talking about your SLS? Do you use it alot of road? If when you lower it one side is sometime lower? Does this happen when you are just driving around town, will it just drop a little and if so what do you have to do to bring it level again?
As for the Bilstein shocks, they are slightly shorter then the factory shock, if you are going to install a lift they won't work as well due to their total length. Do you also have ACE?
cranky
Oct 8, 2009 07:18 PM
krazzz
Oct 6, 2009 08:04 AM
maddisco
Feb 4, 2009 08:33 PM
javoli001
Jun 3, 2008 10:18 AM
chelo
Apr 13, 2006 02:11 AM
