Black discharge from exhaust
Old Jul 7, 2008 | 02:56 PM
pc jamie's Avatar
Default Black discharge from exhaust
I have a 99 Disco II with 130,000 miles.
This morning I noticed a black spot on the ground at the exhaust pipe. The truck was running at idle for 2 or 3 minutes as I moved another car from the driveway. I did not see any smoke. The tailpipe does seem to have a buildup of black soot.
Any thoughts?
Old Jul 7, 2008 | 03:22 PM
Default RE: Black discharge from exhaust
Is your check engine light on? Sounds like you are running too rich, check your air filter first, a clogged air filter can cause this, when was the last time you had a tune up?
Old Jul 7, 2008 | 03:27 PM
98roverguy's Avatar
Perfectly normal. The condensation mixes with the carbon deposits and drips onto the ground. Unless your getting terrible gas mileage your perfectly fine.
Old Jul 8, 2008 | 07:03 AM
pc jamie's Avatar
Thanks for your help!!!
Yes the check engine light is on. The truck had plugs and wires in April of 08.
Now that you mention it, fuel consumption is pretty bad. I always runhigh test.
I am going to have the codes looked at today.
Old Jul 8, 2008 | 08:25 AM
Go get your check engine light codes checked and get back to us. At 130,000 miles you have have all sorts of tune related issues showing up, and as already mentioned, all Rover's run real rich at a cold idle and a small amount of soot can be expected.
Old Jul 8, 2008 | 05:02 PM
You probally need O2's.
How is the trk running otherwise?
richard forsyth
Oct 22, 2013 08:48 AM
Messenjah07
Feb 15, 2011 01:34 AM
sean2k
Feb 2, 2010 05:01 AM
arianamini
Nov 12, 2008 11:23 PM
Dahne23
Feb 22, 2008 09:22 AM
