bleed sequence, RHD /LHD ?
Old Jan 25, 2009 | 11:53 AM
NiteTrain's Avatar
Default RE: bleed sequence, RHD /LHD ?
ORIGINAL: llPANCHOll
I take it to cycle the ABS pump you would have to have the Ignition on???
Does the car have to be running??
that is a good question.. also, one more thing on the sequence...rave manual states 'braking efficiency may be seriusly impaired if the incorrect bleed sequence is used'
So which is correct? all of us or the rave manual?
Old Jan 25, 2009 | 02:03 PM
Again the Rave is wrong.
As just mentioned, always start from the furthest point, hence, r/r, l/r,r/f and l/f.
Always use DOT 4, apx 3 pints is needed.
Old Jan 25, 2009 | 02:24 PM
NiteTrain's Avatar
mike, what about PANCHOs question..does the vehicle need to be running to purge the pump?
Old Jan 25, 2009 | 04:18 PM
nynole's Avatar
ORIGINAL: Disco Mike
Is the Rave CD a copy of the factory service manual? Does this mean that the dealership techs are incorrectly bleeding brake lines by following the service manual? I have serviced my brakes according to the Rave CD and have not had any issues (yet).
Old Jan 25, 2009 | 05:55 PM
llPANCHOll's Avatar
I doubt it..
You would know if you were having brake issues
Old Jan 26, 2009 | 10:20 AM
04BluDisco's Avatar
Bled the brakes on the Left Hand Drive yesterday... started with the RR, LR, RF, LF (i.e. farthest away working closer).... braking worked fine.
Definitely interested in hearing if the car needs to be running to cycle the ABS, or of just depressing the pedal for 30 seconds with it off takes care of it.
Boy, that fluid was filthy....
Took me about 20 minutes and exactly 1 quart of fluid.
Raider TD5
Defender
Jun 12, 2014 06:01 AM
Nikola123
Sep 13, 2009 01:00 PM
kean
Apr 2, 2009 11:32 AM
Tomas
Defender
May 5, 2008 03:01 AM
dr.rover
Oct 26, 2007 12:39 AM
