Bleeding brakes / Foxwell NT630 plus
Does anyone know if a Foxwell NT630 plus can be used to bleed brakes?
If not, is there a diagnostic tool that will work for bleeding, that doesn't cost an arm and a leg?
I tried using my Foxwell before. It's been a while, so I don't recall just what happened or didn't happen, but I think I recall finding the steps in the menu, but nothing happening,
You don't need a scantool at all -- just some long wires and a switch. https://landroverforums.com/forum/di...estion-107246/
I've tried bleeding by running the pump with long wires and a switch, still got a problem with brakes. Not sure it's air still in the module, but would like to do the best I can to eliminate that.
Brandon318
Aug 10, 2020 09:41 AM
