Blew lower radiator hose
Old Aug 28, 2023 | 12:06 PM
aututto's Avatar
Default Blew lower radiator hose
So i've been flushing all week, finally got the 180 t stat. My idiot self forgot to put the clamp on the lower radiator hose and blew the line on a short 5 min drive. The ultra gauge never got over 220, would I have caused any damage?
Old Aug 28, 2023 | 12:16 PM
ahab's Avatar
Unlikely, unless the ultragauge never got any higher because there was no longer any hot liquid surrounding it. Before freaking out put her all back together and fill it with distilled water, then bleed it a couple times to see what happens.
Old Aug 28, 2023 | 12:36 PM
mln01's Avatar
A "momentary" temp spike is not likely to warp the heads and cause head gasket failure.
My wife drove my truck three hours back from the beach many years ago, and told me when she got home that there was this red light on in the instrument panel.
Yeah, uh, that'll do it ...
Old Aug 28, 2023 | 01:13 PM
aututto's Avatar
I went and backtraced, looks like it blew a mile from my house, I had only been on about a 3 mile drive. Thanks all sounds like I should be ok!
Old Aug 28, 2023 | 03:43 PM
Discorama's Avatar
I always wondered if it makes sense to have a gauge for coolant pressure. Your incident answers my question. You would notice a leak some time before the temperature goes up.
Old Aug 28, 2023 | 03:50 PM
ahab's Avatar
I think you'd be better off doing it with a level sensor in the overflow bottle. Especially if you run your cap loose and thereby get no pressure. That has saved me many times over the years in my other cars.
Old Aug 28, 2023 | 04:57 PM
aututto's Avatar
I agree. Had I seen pressure loss I would have stopped immediately. Gauge stopped around 217, coolant was probably all out by then. That was about a block from my house so hopping it didn’t do too much
positive note the temps look great now with OEM 180!
iandemel
Mar 26, 2015 01:18 PM
ryans97discovery
Oct 7, 2013 03:58 PM
Rob145
Jul 28, 2010 07:56 AM
mag48
May 18, 2009 10:58 PM
awsherwo
Apr 10, 2006 11:40 PM
