Is the Block Junk?
Old Feb 19, 2019 | 08:24 PM
Stoney83's Avatar
Default Is the Block Junk?
For fun I tore apart the block from my parts truck. It had one slipped liner that punched threw the head gasket a bit with no erosion on the block face or head.
If its junk I don't really care... I'll make a coffee table out of the block and the water pump looks basically new
Are there any other parts to keep? Heads? Lifters? Cam? ect?
Old Feb 19, 2019 | 09:20 PM
The_OGCJR's Avatar
Sounds like the block could be sleeved or the liner could be pinned and you could still use it if needed.
I wouldn’t keep rods, or even rocker shafts It’s not that expensive for new ones.
I may keep lifters depending on how they look and look and I would keep heads.
Keep cam if lobes are ok
Old Feb 20, 2019 | 06:43 PM
bcurtman's Avatar
Keeping lifters is ok, but only if using them with that cam, and ideally on the same lobes they came from. Never put used lifters on a new or different cam. You'll waste it all.
Old Feb 20, 2019 | 07:23 PM
The_OGCJR's Avatar
i forgot that
Old Feb 20, 2019 | 09:05 PM
Extinct's Avatar
Wow that is a clean lifter valley!
Old Feb 21, 2019 | 03:34 PM
Stoney83's Avatar
Makes since on the lifters and not mixing and matching new stuff with old.
That's what did in the the prior owners rebuild..... too cheap to change and oil pump.
I guess keep the heads, cam, crank, starter and new water pump that was on the engine.
Matt Brown
Feb 19, 2019 06:16 PM
hrhoward
Nov 21, 2018 03:44 PM
slammin_LWB
Nov 23, 2016 11:31 AM
abran
Jun 3, 2015 03:23 PM
03discoman
May 9, 2010 02:08 PM
