Misfire
Old Feb 21, 2019 | 04:57 PM
James.Harris2's Avatar
3rd Gear
Default Misfire
Fishing for some info. 2002 Disco 2. Has a code for cylinder 2 misfire along with code for multi cylinder misfires. After pulling the plenum I found a decent amount of engine oil. It actually ran out of the bottom of the plenum. It was also prevalent in the throttle body. Any thoughts.
Old Feb 21, 2019 | 05:05 PM
redwhitekat's Avatar
Check out the pcv valve mod on here and install one ASAP
Old Feb 21, 2019 | 05:16 PM
3rd Gear
Thanks a lot will do.
Old Feb 21, 2019 | 05:25 PM
Extinct's Avatar
Swap spark plug wire 2 with a different one and see if it follows the wire. Most single cylinder misfires are bad plug wires.
TheSloth
Aug 1, 2017 11:57 AM
LR03NJ
Feb 26, 2016 08:12 AM
LRScott
Mar 14, 2014 10:12 PM
Bryan H
Sep 3, 2011 10:42 AM
Bryan H
Sep 1, 2011 12:48 PM
