Block weight
Old Jul 18, 2017 | 05:34 PM
Sixpack577's Avatar
Default Block weight
Does anyone know roughly what an 04 Bosch 4.6 aluminum engine block weighs?
Bare, no crank, nothing.
Thanks
Old Jul 18, 2017 | 07:59 PM
Jeff Blake's Avatar
Around 60-80 pounds if I remember right
closer to 60. Easily lifted on your own
Old Jul 18, 2017 | 09:11 PM
00&04 Disco's Avatar
Thanks
I agree around 60 lbs. I just had mine stripped down last week and picked it in and out of the truck bed no problem.
Old Jul 18, 2017 | 09:24 PM
Sixpack577's Avatar
That's it!?!?
That's great!
Reason I ask is that in the near future I have to replace valve cover gaskets. While I'm at it, I'll be searching for whatever is causing the tick.
If it's a cam bearing, I'm pulling the engine.
I'll drop the crank first, heads off, ect.
I can pull the engine apart in it.
Saves me the hassel of borrowing a friend's engine crane, laying plywood on gravel driveway for it to roll, and getting it into my garage (Disco is too tall to fit under my garage door lift arm).
I like to have a plan before I start a job.
Thank you guys so much!
humroot
Jul 22, 2019 06:33 PM
Noble Six
Jun 4, 2014 04:51 AM
Blakesrover
Feb 21, 2013 01:43 AM
JBEGIN
Jun 27, 2009 12:38 PM
weatherman
May 3, 2007 05:12 PM
