Bloody Stuck Bolts in Head Gasket Removal
Old Sep 5, 2023 | 01:49 PM
PNW_disco2's Avatar
Default Bloody Stuck Bolts in Head Gasket Removal
So so so close to having the bloody headgaskets out. Having a HELL of a time removing these bolts. Any advice on how to loosen them? Have tried WD-40 penetrating - they are NOT budging
Old Sep 5, 2023 | 02:24 PM
Harvlr's Avatar
Head bolts need at least a 2 1/2 foot bar to turn. They are “Torque To Yield” bolts and are very tight.
Old Sep 5, 2023 | 02:27 PM
Harvlr's Avatar
And I would suggest something to protect your windshield from breaking when your socket slips off the bolt head. I put a piece of old plywood over it.
Old Sep 5, 2023 | 02:41 PM
mollusc's Avatar
And remember not to loosen anything past the crack point until every one of them has broken free.
Old Sep 5, 2023 | 05:09 PM
gecko951's Avatar
You can try taping around the outside head of the bolt with punch and a hammer; also give the bolts another dousing of penetrating oil and let it sit overnight.
Old Sep 5, 2023 | 07:10 PM
Extinct's Avatar
Make sure you have a tight fitting impact socket. Be sure clean everything out from around the bolt heads on the short ones in the end of the head down in the pocket. Put a little valve grinding compound on the inside of the socket to help grip the bolts.
Old Sep 5, 2023 | 07:51 PM
PNW_disco2's Avatar
@Harvlr could you be more specific with what you mean by 2.5 ft bar (photo or link)? I'm a visual person, not understanding what you're referring too.... I still have the bonnet attached but sounds like it may need to come off...
Old Sep 5, 2023 | 07:55 PM
PNW_disco2's Avatar
Thanks @mollusc
@gecko951 not sure what you mean by a punch (rubber mallet?)
@Extinct Ahhh, I definitely don't have a tight fitting impact socket.... will def invest in some valve grinding compound, great idea - thx
Would using a propane torch help? Or an induction heating bolt remover machine?
Old Sep 6, 2023 | 12:19 AM
gecko951's Avatar
Cold punch...your local auto parts store, hardware store or neighbor who likes to work on classic cars should have a set.
Old Sep 6, 2023 | 12:25 AM
gecko951's Avatar
You want a 30 inch or longer breaker bar...something like this:
Amazon Amazon
