Blown Head Gasket?
Old Sep 13, 2015 | 05:30 PM
  #31
OffroadFrance's Avatar
Originally Posted by Daedrix
Day 2. Didn't get much done.
Front cover off.
Oil pump gear looks good but replacing it since i have a new one.
Timing chain.
It looks like you're doing all the right stuff Daedrix. One area concerns me though, in photo#3 each side of the timing chain there are two coolant ports, one each side, they seem full of white crud which looks like either calcium build up or maybe some coolant additive. If either it'll pay to flush out the cooling system with some mildly acidic fluid, I use central heating cleaner mixed with DI water and left in for a few days and then flushed out and backflushed. I tend to do this without a thermostat as it rushes around the system a lot faster and has a scouring effect. just a thought.
Old Sep 15, 2015 | 09:26 PM
  #32
Daedrix's Avatar
Banned
Day 3.
Front cover with all the new bits installed.
Oil pan
New gasket installed.
Old Sep 16, 2015 | 07:05 AM
  #33
drowssap's Avatar
i have to say as far as sludge goes that's one of the better engines i've seen opened on here.
Old Oct 1, 2015 | 01:32 PM
  #34
Daedrix's Avatar
Banned
Been a while since i updated but im all done.
Got heads back.
The install.
Finish for that day.
Swapped out valve cover hardware.
Front bits installed with the help of a friend.
Installing the electric fan i bought while on deployment.
That's my friend being an ***
This is what happened to my sia pipes.
so i ordered new ones off ebay.
Had them capped while i was waiting on the delivery. drove around for 2 days like this no codes.
Disco's all put back together and running fine ill edit this portion with the rest of the picks later.
Old Jan 26, 2016 | 08:10 PM
  #35
Daedrix's Avatar
Banned
Well its been 5k miles since i changed my head gasket and I've had no issues since...well not with the engine at least. I did break my: transmission, front passenger half shaft, and another rear diff so just the normal rover stuff.
One another note the pics in this thread weren't showing up so i fixed all of them.
Old Jan 26, 2016 | 08:35 PM
  #36
jamieb's Avatar
Thanks for all the details and pics. I paid $2400 for the job a few months back. Since then I've gotten more familiar with my truck and plan to do more myself. Great job!
Old Jan 28, 2016 | 07:29 AM
  #37
MPDano's Avatar
Great pics. I too have to do that head gasket job. What did the cylinder head service cost you?
Old Jan 28, 2016 | 07:49 AM
  #38
dgi 07's Avatar
how is that fan setup treating you?
Old Jan 29, 2016 | 07:26 AM
  #39
Daedrix's Avatar
Banned
The fan is doing good my max temp is usually around 220f but i plan on doing an inline t-stat because i dont thing the 180 t-stat i bought during the install is a 180. I also plan on trying a vented hood mod and see if the temps go down any.
Old Jan 29, 2016 | 07:32 AM
  #40
drowssap's Avatar
you temps are averaging 220F? is that with both fans running? the condenser fan should be coming on around 210.
