blown oil filter
Old Oct 17, 2011 | 10:22 AM
troyc's Avatar
4th Gear
Default blown oil filter
ok so i did the head gaskets this weekend along with timing chain and gears , i also took apart the oil pump to have a look and pulled the check valve out of the front cover. now the thing has blown the oring out of three filters has anyone had this issue ? what should i be looking for ? its a 2000 d2 4.0 litre , any suggestions ? troy
Old Oct 17, 2011 | 10:24 AM
do you have an oil cooler, might have restriction in there, some D2's had them, below rad near tranny cooler.
Old Oct 17, 2011 | 10:53 AM
troyc's Avatar
4th Gear
yes it has a cooler , everything was fine until i put it back together
Old Oct 17, 2011 | 11:33 AM
Go into the Rave and read up on the valve and the oil pump.
In the mean time, do not start the engine again or you may blow either the rear main and or front seal also.
Old Oct 17, 2011 | 12:03 PM
antichrist's Avatar
How tight have you been tightening the filter? 1/4 turn after the seal contacts the mating surface? Or more?
Old Oct 17, 2011 | 01:36 PM
see attached pages from overhaul manual - perhaps check re-assembly of oil valve parts. With respect to sping length, I believe I saw a post about two different length springs, based on serial number. Main thing is parts positions.
File Type: pdf
File Type: pdf
File Type: pdf
Old Oct 17, 2011 | 01:41 PM
RoverMasterTech's Avatar
you put the valve in backwards. a couple came out of the factory like that.
Old Oct 17, 2011 | 06:33 PM
atancreti's Avatar
Do a psi check once you get this solved. Would be interesting if you had "high" PSI. lol Doubt thats it. How tight is oil filter?
Old Oct 17, 2011 | 06:50 PM
troyc's Avatar
4th Gear
i put the valve in backwards , dont know how that happened.
Old Oct 17, 2011 | 07:42 PM
SALTY II's Avatar
5th Gear
Glad you got your problem solved.
What's the concern with the oil filter?
rikdburns
Feb 27, 2010 06:37 PM
mike.anna
Apr 13, 2007 09:57 PM
DefenderTd5Dude
Defender
Mar 20, 2007 04:22 PM
bigugly82
Mar 6, 2007 10:55 PM
fuel
Dec 13, 2004 04:49 PM
