Blue Devil, the verdict is in
Old Jun 15, 2018 | 03:09 PM
  #21
MrNails's Avatar
Looks more like a Dex Cool problem than a blue devil problem.
Old Jun 16, 2018 | 05:27 AM
  #22
shanechevelle's Avatar
Glad I'd rather do things the right way. I've seen you many clogged radiators, heater cores and worn out water pumps to even try something as obviously stupid as this.
The head gasket breaks at the rear of the head due to the placement of the head bolts.
Anyone still using dexcool is asking for trouble.
Old Jun 16, 2018 | 12:39 PM
  #23
redwhitekat's Avatar
I use green coolant and 180 Tstat
what I find amazing is Atlantic British and dealers all recommend dexcool and never replace the oem Tstat to a 180 my 03 was dealer serviced up until last year and still all oem parts
when I got it it was running 215-225
Old Jun 16, 2018 | 02:17 PM
  #24
What's wrong with that? It's a little close to the threshold to blow but itll operate fine at those temps.
My saab runs to 240 up hills. Been that way as long as I can remember.
Old Jun 17, 2018 | 03:46 AM
  #25
OffroadFrance's Avatar
IMHO all 'fix in a can' products are just expensive 'snake oil' and you'll pay later and still need a 'proper' engineering fix plus blocked oil/waterways, whatever. c'est la vie.
Old Mar 17, 2019 | 09:33 AM
  #26
Mike53's Avatar
Default Dear sir,Sounds like it went down
Originally Posted by Doug Higby
Now that I'm holding the Blue Devil Head Gasket Sealer (with yellow label), it clearly says to flush all coolant and to use with pure water. Maybe the can didn't always say this, but it does now.
But it also says the engine must be cold. That made me wonder...
If I pour it into the overflow tank, by the time it mixes with the engine coolant it will be piping hot. So I looked on the Blue Devil website and found this :BlueDevil Pro says:
May 12, 2014 at 3:51 pmIf your vehicle has a reservoir/overflow rather than a radiator cap, instead of pouring it through the reservoir/overflow, with the car off and engine cold, you may add the product through the top radiator hose. Once it has been added reconnect the hose and start the idle from that point.
So that is my plan. I'll post back.
So I am going to do the same thing my question is when you added the blue devil into the radiator with it dry and cold add the blue devil the big bottle first connect hose back to radiator then start motor and add distilled water into reservoir until it overflows While running so the blue devil immediately goes into the motor while mixing with water ?If I understand you correctly I am going to do it the way the blue devil site says.I have my old thermostat Which I was going to drill holes into it so I can get a free flow.I read in a form that a guy used 3 bottles of the big ones and repeated the 50 minutes cycle 3 times before he’s oil was clean?I guess I will check the dipstick after the first cycle and see if water is still present if not I’ll call it good if not I will keep running cycles until the oil is clean what is your take on this for mine definitely overheated and have water in oil so this occurred like five months ago and I drained all fluids going to put new battery,Spark plugs and the cheapest oil I can find and keep running cycles till the oil is cleared then drain it and put in my normal oil I am praying on bottle does it,I ask a Land Rover ACE certifiable Mec And this is what he said.Another thing is after I over heated it it died in my drive way after running hot for about a mile till I realized what was going on when steam bellowed out for under the hood I Let it cool over night and did inspections and it was a bad water pump.I started it up cold and it ran for 30 seconds then died I didn’t try anything but get advise so I have everything I need and thank you for all the tips,The reason it died Fast mechanic told me is the coolant fowled out the plugs so how is it going to idle long enough to let the blue devil run it’s cycle if I have all these cracks won’t it fowl the plugs immediately ? This is my horror?Any feed back please!
Old Jan 14, 2024 | 10:55 AM
  #27
Cedes's Avatar
Default Blue Devil is the go!
Originally Posted by ljdiscovery
By way of background, I bought a 2000 Discovery a couple of weeks ago. The PO told me that he had it diagnosed with a bad head gasket and likely in need of a new engine. He had parked it last year and it had been sitting his garage since. I bought it sight unseen and had it towed to San Diego from LA. I was ready to put in a new motor. I charged the battery and it started right up. It seemed to run great, other than a squeeky belt pulley.
I did notice at least three distinct head gasket leaks, one from each side at the back of the engine and one on the front corner of the driver's side. The leaks were such that a drip would develop every 3 or 4 seconds and run down the block and drip onto the ground while idling. There did not appear to be any combustions gases leaking into the cooling system, it looked like it was all external. I also check all of the spark plugs and they all looked good.
I have used White Shepherd by Universal Products on the transfer cases on a couple of my Discoverys with good results (I have no affiliation with Universal Products). Universal Products also makes a head gasket fix called BLUE DEVIL. They have two formulas, one Mechanic Style and one Pour-N-Go. The Mechanic formula requires a free-flowing system, ie removal of the thermostat. I couldn't figure out how to disembowel the thermostat so I decided to use the Pour-N-Go formula. Both formulas require an engine that will idle for 50 minutes without overheating. (I did a test idle on my engine and the temp held steady without significant coolant loss for more than an hour).
I ordered the BLUE DEVIL Pour-N-Go from Advance Auto, they sell a 32 oz. bottle for about $60 (the website shows the Mechanic Formula but they actually sell the Pour-N-Go). I could only find the Mechanic formula locally.
I put it in last night and after the required 50 minute idle, let it sit until this morning (with no radiator cap on the DII, I removed the top hose drained enough coolant and poured the BLUE DEVIL into the radiator through the top hose). I have driven it around all day, up to an hour at a time and so far, knock on wood, there isn't a drip present anywhere! Dry as a bone. The temperature gauge reads just below mid-line and the truck runs great. It is still early and I will give it more of a test this weekend, but for now it looks like it took care of the head gasket leak and may have saved me $$$. This will likely not work for all head gasket leaks, but for smaller, external leaks, it might be the answer.
Phil
1999 DI
2000 DII BLUE DEVIL Guinea Pig
2001 DII
I used Blue Devil Pour N Go in my Audi A41.8T 6 speed. It had coffee coloured oil from so much water being in it. Drained the oil, drained the coolant, put in new oil, filter and water, disconnected offending cylinder, put in Blue Devil and ran on 3 cylinders until it warmed up for 10 minutes. Then ran on 4cylinders for 40 minutes. Then drained oil and water again. New oil, filter, water. Guess what? No more head gasket leak, and it was BAD. Saved me $3000.
Old Jan 14, 2024 | 10:59 AM
  #28
Cedes's Avatar
Default Renault and Hyandai are next!
I am about to put Rear Main Sealer into the Renault and Hyandai. Bad leaks coming from both. Blue Devil is guaranteed to be a permanent fix. Pretty amazing stuff, in my experience using it.
Old Jan 28, 2024 | 07:28 AM
  #29
adolfojbonilla's Avatar
Please keep us posted, thinking about pouring a bottle to try and fix a rear main seal on my 2002 Discovery S2 SE.
Old Jan 29, 2024 | 07:46 PM
  #30
teamharper0808's Avatar
Default BlueDevil
I just had this done on my 2012 HSE. It was either this or another motor.
a-rod
May 8, 2013 06:35 PM
starcraft1
Nov 13, 2011 08:14 PM
BraziliaNut
May 24, 2011 05:42 AM
Huckleberry77
Mar 11, 2011 10:31 AM
ljdiscovery
May 21, 2010 09:39 AM
