BlueLake Offroad bumpers
Old Apr 22, 2015 | 07:41 AM
acamato's Avatar
Old Apr 22, 2015 | 07:51 AM
antichrist's Avatar
Originally Posted by cybercop
Never thought of it that way. Interesting.
Would you have a good recommendation for 3" fog lights, besides fab'ing a bracket for the stock ones.
Here's a link to good information on fogs. You can use the information when shopping.
Daniel Stern Lighting - Fog Lamps
But you have to be careful, just because it says "fog" in the ad, often they aren't.
Old Apr 22, 2015 | 08:12 AM
drowssap's Avatar
remember all those lights are going to require that you damage the power coat.
Old Apr 22, 2015 | 09:30 AM
cybercop's Avatar
Yeah, in your opinions, what is the ramifications of that. My body guy seems its not that big of deal if you drill it right, seal the exposed metal to powdercoat, and make sure what ever light I choose actually clamps around enough, bites enough, past where the powder coat was damaged/cut.
He said the pressure point of the light mounting will take the stress of the exposed edges.
Old Apr 22, 2015 | 09:42 AM
drowssap's Avatar
my honest opinion: TP powder coat sucks, it more like a plastic dip, you can cut it with your finger nail.
But with that said; I think if you find a light that is sandwiched between the bumper using an outside cover, if you caulk the fixture you will be ok.
I plan on doing my bumpers in bedliner when I have time, at least that will hold up to minor scrapes.
Old Apr 22, 2015 | 12:08 PM
cybercop's Avatar
"TP Powder coat sucks" What is TP Powder coat. Is that different than typical powder coat?
We have our dirt bike frames, swingarms and other stuff powder coated all the time, and it isn't anything like Plastic Dip. Very durable.
Does the powder coat that Terrafirma use suck really bad?
Old Apr 22, 2015 | 12:19 PM
drowssap's Avatar
should have read Terra Firma powder coat, yes in my opinion it sucks.
it will be nothing like your bike frame or swing arm I can assure you.
I have heard bullsh*t line about the European powder coat standards are less,
but you cant see that by my BMW r100.
But that JMHO
Old Apr 22, 2015 | 12:58 PM
cybercop's Avatar
But that JMHO
Gotcha,
I guess my approach is to be as careful as possible with heat generated when drilling. Put about 3 layers of blue masking tape on both sides of the hole. Maybe use a colbalt twist drill bit at low speed with machine oil instead of using a hole saw bit. Start much smaller than the hole needed and work my way up to about 1/8" of the minimum clearance needed. Sand the edges of the powder coat to prevent cracking and finish with a dremmel etching bits. Finish off the edges with some car touchup paint.
Should be good to go!
Or, just take it to a machine shop that knows what the F they are doing. Better for blood pressure.
Old Apr 22, 2015 | 01:02 PM
drowssap's Avatar
put the lights, when the powder coat starts coming off down the road; just paint it.
who knows maybe they us real world standards now, mine is 2 years old.
Old Apr 22, 2015 | 02:14 PM
cybercop's Avatar
Well, forget the twist drill bit. A 1 1/2" bit is over $150. I would hate to see what a 3" bit costs.
To a machine shop it is!
yzblue125
Dec 30, 2010 07:46 AM
KBW
Mar 24, 2009 06:28 PM
derrickalda
Appearance & Camping Set Ups
May 9, 2008 12:08 AM
Benhamtroll
Apr 20, 2005 05:46 PM
Trader4Less
Feb 22, 2005 03:09 PM
