2003 Disco 2 transmission issue / flashing d (in drive)
Old Apr 21, 2015 | 05:09 PM
texmanmoore's Avatar
Smile 2003 Disco 2 transmission issue / flashing d (in drive)
I recently purchased a used 2003 disco 2 off eBay. Car has a few issues that I'm trying to fix. It has 106,000 miles. My issue is intermittent , worst kind right. Most of the time when puttimg the transmission in D /drive it's all good. Shifts fine no issues , u can put the shifter in 3rd 2nd and it shows you on the dash the gear ur in..
However SOMETIMES you put the transmission in gear Drive it flashes D on the dash, and continues to flash d. Seems to be stuck in like 3rd gear , sluggish to take off , can't feel any shifting. 60 mph is like 3500 RPM,s
Also when u try and put the transmission in a lower gear like 3,2 it still flashes D and won't down shift. help please I need to find out if this is common and what the fix is. Seems to happen in mornings and maybe moisture related ?? If that makes any sense.
Old Apr 21, 2015 | 05:22 PM
OffroadFrance's Avatar
Sounds like it's going into 'limp home mode' i.e 3rd gear only and no gearbox changes. Does the M&S lights come up simultaneously? It could be a few issues, the battery charge is too low, the xyz switch is defective or needs adjusting or just a gearbox ECU glitch.
Old Apr 21, 2015 | 06:25 PM
I have never seem any m s lights. Where would they be luminated on the dash ? I do have a check engine light on but so far engine is running smoothly. I looked for this xyz switch. I hear it near the ac evaporator drain it it large and on the frame rail ? I'll check the battery charging. I did put a new battery in after I bought and assume it's charging. Is that was your suggesting the alternator is charging correctly ? Thanks for ur help.
Old Apr 21, 2015 | 07:01 PM
abran's Avatar
The XYZ switch is mounted on the driver side of the trans, follow the shift cable to it.
It electronically sends a signal to the computer informing it what gear it is in.
Old Apr 21, 2015 | 11:29 PM
cappedup's Avatar
Have you checked/changed transmission fluid since you bought it?
Old Apr 22, 2015 | 07:31 AM
No I have not. I need to check the fluid level. And should change the fluid. Is old fluid able to cause this problem I'm having ? Thanks
Old Apr 22, 2015 | 08:18 AM
drowssap's Avatar
check to make sure your battery is good, check to make sure your alt. is putting out at LEAST 13 volts them check your grounds.
there a quite few thing that can cause this problem, XYZ switch being the most expensive.
you are in limp mode because you trans. computer saw less than 13 volts,
I would start with the cheap stuff first.
Old Apr 22, 2015 | 08:33 AM
cappedup's Avatar
No. Old fluid would probably not cause the things you describe. But 'no' fluid might. And if you haven't looked you don't know it's in there.
It's the first thing I do when I buy a vehicle is get to know the state of it, as much as possible. Change the fluids as soon as possible. Then, when something crops up, you at least have some standing to work from.
I agree, checking voltage is the quickest cheapest thing to do. Second up would be change the fluid, for my $.
Old Apr 22, 2015 | 12:34 PM
Thank you for the good info
Old Apr 22, 2015 | 03:08 PM
Fast951's Avatar
Be sure to read up (use Search function in this forum) on how to service the transmission. There is no dipstick to check the fluid level up in the engine bay (yes, we all agree this is stupid) and changing the fluid and filter is likely different from any vehicle you've owned previously. Unless it was made in the UK.
importdave
Sep 25, 2014 10:18 PM
javoli002
Mar 1, 2009 03:39 PM
gsgtsg
Jan 23, 2008 01:46 PM
MallCop
Dec 17, 2007 07:46 PM
valpo48
ROAMING WITH FRIENDS
Oct 3, 2007 06:38 PM
