Bosch vs Walker vs foreign O2 Sensors
Old Sep 20, 2021 | 09:09 PM
jbullard's Avatar
Default Bosch vs Walker vs foreign O2 Sensors
As a follow up to my previous post, what has been everyone's experience with O2 sensors? I have seen several comments saying always buy Bosch, with some chipping in that they have had good experience with Walker as well. Everyone soundly agrees to not buy cheap foreign made sensors. What has been the specific experience after purchasing a cheap foreign made one? Did it stop working after a short period of time? Did it just not work from the get-go? I made the choice (mistake? after reading several comments) to buy a cheaper alternative sensor (Drivewire brand) which didn't fix my issue.
Old Sep 20, 2021 | 09:12 PM
thebilgerat's Avatar
Having just gone through this I ordered both front and back from a well known LR parts house. They were Walkers. The two fronts did not work - instantly threw codes. One never worked, the other worked intermittently. Decided to get OEM Bosch replacements for the front two. Worked like a charm. As always YMMV, but my rig definitely only wanted Bosch. Of course, I could have gotten a bunk batch, but if I were you I'd save yourself my headache and just get Bosch.
Old Sep 20, 2021 | 09:22 PM
Sandman614's Avatar
Bosch that were on it when I bought it started throwing codes, replaced with Bosch threw same codes, replaced with walkers still threw same codes, replacing the Cats now.
Old Sep 21, 2021 | 06:41 AM
mollusc's Avatar
I've only used Walker replacements on two different trucks, and also on my wife's car, with excellent results. I can't give any comparison data since I've never used anything else.
Old Sep 21, 2021 | 08:42 AM
dtmbinb's Avatar
Walkers here.
Old Sep 25, 2021 | 05:32 PM
jbullard's Avatar
Thanks everyone for the input. I was hoping to order some replacements to fix an issue with my Bank 2 sensor 1 but I determined that it's actually not the sensor after all after switching sensors with the working side of the vehicle.
now I'm not sure what the deal is... Since it's not the sensor I stripped back the protective corrugated cover on the ECM side wires and found that the signal and signal ground wires (blue and red correct?) join into a cable. It looks like someone did some work at some point because there was a heat shrink piece where the cable insulation ended, and there was also a bare stranded wire that just ended under the heat shrink.. any idea what that wire is for? It doesn't connect to anything on the sensor side currently and I don't see it on the circuit diagram. I would think ground wire but there is already a signal ground wire...
Old Sep 26, 2021 | 09:22 AM
JUKE179r's Avatar
For me… Bosch for all other parts EXCEPT O2 sensors. NTK FTW!!!
Part #25623 UP & #25624 DOWN.
Old Sep 26, 2021 | 12:18 PM
jbullard's Avatar
Interesting - thanks!
NVDiscovery
Jun 14, 2021 07:54 PM
arains44
Sep 20, 2020 02:16 PM
Fastercat
Nov 1, 2019 07:26 PM
redwhitekat
Aug 3, 2018 06:29 PM
hankeester
Feb 13, 2014 01:29 PM
