Both Rear Axle Seals Leaking
Old Nov 30, 2020 | 08:56 AM
CollieRover's Avatar
Tektron is going to send me a new breaker bar. They don't make mine anymore so they are sending an upgrade. I will buy tektron from now on. Great service, and prompt.
Old Nov 30, 2020 | 09:36 AM
zski128's Avatar
Some notes as I just replaced all 4 hubs. Porter Cable electric corded impact gun $75 from HD or Amazon. Takes it right off. The stock axle nuts are 32 mm but the replacements I got from RockAuto where 36mm and the socket will not fit through the rim.
Old Nov 30, 2020 | 09:39 AM
Is it ok to use heat(propane torch) on the axle nut?
Old Nov 30, 2020 | 09:40 AM
I have a couple impact guns I am going to try as well. This one is tougher than both my front were.
Old Nov 30, 2020 | 04:57 PM
The Deputy's Avatar
Yes, you can use heat...just don't go crazy. Sometimes, folks will get it cherry red and zip it off...and the red hot nut will destory the threads on the axle shaft. Just get it slightly red and remove.
Old Dec 1, 2020 | 06:40 AM
All I have is propane so I don't think I will have that issue.
Old Dec 6, 2020 | 08:58 AM
I bent my 3/4" Break Bar last try, so I contacted Tektron, and with just a text and a note they sent out the new improved model for me. This one is 40" Long and has a heavier duty head design. So from now on I will be ordering Tektron. Craftsman's warranty is super tough to use, this couldn't have been easier or quicker, they even gave me advice on the axle nut.
So going to heat it up now, and see if I can get it off.
Tony Luna
Nov 16, 2020 02:01 AM
TATZOO
Oct 30, 2012 10:38 AM
KyShark
Dec 21, 2011 08:01 PM
tsuami1
Jul 3, 2010 01:52 PM
98xc800
Sep 30, 2008 04:51 PM
