Bought a non runner, help get it going
Old Jun 2, 2018 | 11:17 PM
No Doubt's Avatar
Would you think that weak sparks on all plugs would be bad coil packs, wires, or grounding?
Why would the Foxwell turn on the fuel pump, but not your ignition key?
Old Jun 3, 2018 | 09:26 AM
Tucson_Jay's Avatar
Originally Posted by shanechevelle
Did you spray it with fluid like was said or did I miss that?
No, I've never dared use it on a gas engine, due to all the horror stories I heard growing up near the Canadian border. I'm sure it is safe if used properly, and I'm not arguing that it is not.....but old habits die hard.
Old Jun 3, 2018 | 09:43 AM
CollieRover's Avatar
Sounds like there is a reason you got a good deal. The flashing odometer probably means they tried to fix this and could not.
Unfortunately it sounds like wiring.
Old Jun 3, 2018 | 11:05 AM
Best4x4's Avatar
You don’t have to “spray” anything. Remove PCV vent line from intake, dump a little fuel directly into the intake, re-attach PCV/breather line & try to start it. “If” it sputters or coughs = you have a fuel issue. If you get nada zip nothing you have a spark or CPS issue.
Old Jun 3, 2018 | 07:24 PM
Tucson_Jay's Avatar
Put fuel in the intake as described, cranked for a long time.....nothing. Replaced coils with used set and double checked each wire on both ends for firing order....nothing
thought maybe it it was a faulty ground to ecu, followed wiring diagram and it ohmed out good.
Old Jun 3, 2018 | 10:47 PM
No Doubt's Avatar
What error codes are you seeing via the Foxwell?
Old Jun 4, 2018 | 08:31 AM
Tucson_Jay's Avatar
There was a voltage supply code in the ECU which I thought was from the battery being run down. I didn't find any codes in the bcu. I went through the other systems, only thing weird is it can't communicate with the cruise control.
Old Jun 5, 2018 | 01:07 AM
No Doubt's Avatar
I've heard of people getting no error code when they have a bad Crank Position Sensor (CPS). Cheap to replace.
A failed CPS would cause a no spark situation.
Maybe clear the codes, replace the CPS, and retry?
Old Jun 5, 2018 | 08:48 AM
Tucson_Jay's Avatar
Well I can certainly try put the original one back in. I did replace it with a non bosch one from oreilley. According to the foxwell, it is showing cranking rpm, but maybe a bad/false signal???? My other thought was a bad coil(or two) and the used ones also bad, or wires are bad. The pug wires look to be recently replaced, but who knows.
PS, you mentioned getting the BCU/ECU synched(married) with the foxwell. The ECU date of manufacture and the vin number match the vehicle. How do you pair them to eliminate the flashing odometer?
Old Jun 6, 2018 | 02:47 AM
No Doubt's Avatar
Odometer will flash if the dash is not original (VIN doesn't match ECU+BCU). Maybe the Foxwell can put your VIN into the dash?
MRZ
Feb 9, 2018 04:55 AM
toofaroffroad
Dec 21, 2015 01:17 AM
KigomaSteve
Apr 15, 2013 12:55 AM
ParacordPimp
Jan 27, 2011 06:04 PM
crownaviation
Sep 13, 2007 10:08 PM
