Brake booster?
Old Mar 26, 2022 | 01:17 PM
keninnc's Avatar
Default Brake booster?
2003 North American D2
While driving, I'm getting a noise of air being released when I push down on the brake pedal. It is releasing pressure in the system and the brakes are not working very well.
I pulled back the dust shield that covers the area between the firewall and where the brake pedal connects to the master cylinder.
I'm looking on-line for the parts. It seems it may be the brake booster or the could it be master assembly. Both come with an O-ring where they connect. Could the O-ring be changed to solve the leak or more likely the brake booster needs to be replaced?
The sound is defiantly coming from inside and you can not hear anything from the engine bay. Of course the engine needs to be on to get the feedback.
thanks,
Old Mar 26, 2022 | 02:59 PM
Extinct's Avatar
Probably the booster, they develop a leak in the diaphragm.
Old Mar 27, 2022 | 05:39 PM
keninnc's Avatar
Thank you Extinct, your suggestion was correct.
Tarheel Rover parts is not too far away from me and I was able to get a brake booster from him. I got the master cylinder as well from his same donor D2. I did not want to have any issues with the O-rings by separating them.
Lot's of bleeding afterward but now the brakes feel better than before.
mwins
Dec 29, 2021 06:36 PM
hriant88
Oct 18, 2021 11:01 PM
Briex
Apr 15, 2019 06:06 AM
Charlie_V
Dec 19, 2015 04:05 PM
cloaked96
Oct 19, 2008 10:42 AM
