Brake Booster?
Brake Booster?
My 2003 Disco has had "weak" brakes since I picked it up a few years back. The brake pedal isn't spongy and it takes a lot of pedal to come to a quick stop. Sometimes I feel like I need to put both feet on the brake pedal. I replaced the master cylinder and had it bled at a shop but didn't help much with the pedal effort. I know that probably leaves the booster as the primary suspect but before I spend $500 for one is this a common problem?
Pads aren't even 1/3 work and the rotors look fine. If I compare the brake effort on the disco compared to the other cars it's at least 5 times more. The boosters for the Disco are expensive ($700) otherwise I'd just replace it. That's why I was asking if the pedal effort was normal on this model.
