Brake Booster?
Old Mar 28, 2022 | 09:42 AM
jtz54's Avatar
Default Brake Booster?
My 2003 Disco has had "weak" brakes since I picked it up a few years back. The brake pedal isn't spongy and it takes a lot of pedal to come to a quick stop. Sometimes I feel like I need to put both feet on the brake pedal. I replaced the master cylinder and had it bled at a shop but didn't help much with the pedal effort. I know that probably leaves the booster as the primary suspect but before I spend $500 for one is this a common problem?
Old Mar 28, 2022 | 10:58 AM
zacharyz28's Avatar
How do your pads and rotors look? Just because the pads have a lot of meat on them doesn't mean they are not garbage. I just dealt with this and new front pads and rotors did the trick.
Old Mar 30, 2022 | 02:46 PM
jtz54's Avatar
Pads aren't even 1/3 work and the rotors look fine. If I compare the brake effort on the disco compared to the other cars it's at least 5 times more. The boosters for the Disco are expensive ($700) otherwise I'd just replace it. That's why I was asking if the pedal effort was normal on this model.
Old Mar 31, 2022 | 03:04 PM
Motorhead1's Avatar
Make sure you still have the o-ring sealing the MC to the booster
keninnc
Mar 27, 2022 05:39 PM
mwins
Dec 29, 2021 06:36 PM
Briex
Apr 15, 2019 06:06 AM
Charlie_V
Dec 19, 2015 04:05 PM
cloaked96
Oct 19, 2008 10:42 AM
