Brake Booster?
Old Dec 23, 2025 | 09:39 PM
thclark's Avatar
4wd High
Default Brake Booster?
Had a leak from the brake fluid reservoir and also had soft squishy brakes (new to me D2 - 95K miles). Decided to solve the leak in hopes that solving the leak and bleeding brakes for air in the lines would solve my squishy/soft brake problem. Replaced the reservoir and seals with the kit from Atlantic British. Leak gone. Bled the brakes - almost no air to bleed out. Test brakes after all this and they are still squishy/soft - no change. When the car is off, brake is firm on press...when the car is on, brakes are squishy/soft. If I start car when foot on firm brake, the brake turns to soft/squishy when started. Ai tells me its the brake booster? I feel like I'm on the road to replacing the Master cylinder/brake booster/brake lines, etc. etc. Any help/Advice appreciated to reduce my pain and spend - thx!
Old Dec 24, 2025 | 10:35 AM
Harvlr's Avatar
Ideally you should use something like a Nanocom to bleed the ABS portion, but I think you can accomplish most of the bleed by jumpering the contacts at the ABS pump relay.
Old Dec 24, 2025 | 02:53 PM
Extinct's Avatar
You can test booster, connect hand vacuum pump to booster and pump down. It should hold vacuum.
Twillard
Feb 18, 2025 09:28 AM
vietec
LR4
Jun 24, 2024 06:47 AM
cvhyatt
Dec 28, 2021 05:58 PM
FlyingZebra34
Mar 8, 2013 10:05 AM
samaro71
Aug 27, 2010 04:35 PM
