Brake caliper bolts seized up
Old 04-30-2013, 01:56 PM
caymandrew's Avatar
Today I'm pulling off the right front rotor to swap out the ABS sensor and this one is even more seized than the other side!!
This is a prime example of the forces at play here:
Old 04-30-2013, 02:17 PM
ZGPhoto's Avatar
What is that? is that a socket? Should it be a female socket, or is that an adapter?
Old 04-30-2013, 02:24 PM
Ghaniba's Avatar
Looks like a 1/2" to 3/8" adapter?
Yikes.
Dave
Old 04-30-2013, 02:54 PM
bballjames's Avatar
Ya I just had to exchange a set of harbor freight sockets for a new set because my 10mm socket literally cracked in half when I was working on my t-case cover plate!!!
Old 04-30-2013, 03:51 PM
caymandrew's Avatar
Yes Dave, 1/2 to 3/8 adapter. For some reason the only 12 point 3/4" sockets I have are all 3/8 and those damn caliper bolts are on so tight that adapter just twisted like butter! I've never seen that happen before. Anyways the good news is I did finally get them off and swapped out the senson. All good!
Old 04-30-2013, 09:30 PM
umwolverine's Avatar
It took me a good two hours to get the rotor screws out. Now I am wishing I had not put new ones in. I got replacements through rover parts.com
Screw Brake Rotor Locator 4.0/4.6 (Part # SF108201L) - Land Rover bolts\clamps\brackets\washers from Atlantic British
Just for reference. Sounds like they are not needed.
Old 05-01-2013, 05:38 AM
Ghaniba's Avatar
I never put mine back in - but don't forget there is a proper tool for their removal - "Hammer Screwdriver" - Makes these far easier to deal with. I heated mine up with a small propane torch then gave it a couple good whacks. When you hit it, it turns MAYBE 1/8th of a turn or 1/16. But generally, that's all you need, and can just lightly unscrew them.
This isn't the one I have, but you'll get the idea:
Impact Screwdriver Set with Case
Dave
Old 05-01-2013, 10:49 AM
kfx4001442's Avatar
When I did my brake job on all four wheels I didn't have all this trouble. The bolts came right out with a rubber mallets help and the retaining screws on the discs came right out too. I did have to go buy a #3 Phillips head bit. I didnt have one that big and the #2 I had was trying to ring the screws out. Got that #3 Phillips Head bit and it worked perfectly. CRAFTSMAN
Old 05-01-2013, 10:54 AM
ZGPhoto's Avatar
Alabama is not in the rust belt, you guys don't get rust like we do!
Old 05-01-2013, 08:31 PM
kfx4001442's Avatar
True dat lol.
Quick Reply: Brake caliper bolts seized up
