Brake Caliper Seal
Old May 14, 2007 | 10:12 PM
amvauto's Avatar
Default Brake Caliper Seal
In the process of changing my front discs/rotors and pads and noticed that one of the caliper's pistons seal is cracked (the seal the is around the actual piston, just one not the other) are there any kits or replacement seals for this part, is it complicated to change? What suggestions do you have for this, the cheaper the better if possible...otherwise everything else is ok...just the seal around 1 of the pistons...and the screw that holds the disc/rotor in place is stripped...I guess drilling it out is the best option?
Thanks, all input is appreciated
Old May 14, 2007 | 10:21 PM
landbeater's Avatar
Default RE: Brake Caliper Seal
Yes you can purchase a caliper rebuild kit. The directions in the service manualforrebuilding the calipers is very straight forward. I am at work until Wednesday, but could send along text of the instructions then. Have you tried an impact driver on the screw that secures the rotor to the hub?
What year is the rover?
Old May 15, 2007 | 03:24 PM
amvauto's Avatar
Thanks, it is a Disco 2000. This kit, where is it avaiable? I am in Canada...
So what is the actual procedure
Old May 15, 2007 | 07:28 PM
On line thru Atlantic British,or thru Rover Connection. com would be 2 of the more common places to order thru.
Mike
Old May 16, 2007 | 01:31 PM
geoman's Avatar
The kit you need has a part number of STC1919 (Front brake caliper rebuild kit) as sells for about $25.00
regards,
Geoman
www.eurotekapg.com
outdoor7or24
May 21, 2012 08:34 AM
yloDiscoII
Feb 10, 2010 10:03 PM
mburnett
Apr 20, 2007 03:09 PM
i_m_jon
Mar 16, 2007 09:42 PM
