Brake choices
Old Jun 12, 2013 | 08:51 AM
teeboli's Avatar
Default Brake choices
Hey guys I'm going to replace rotors and pads all around on my 04 SE7 and I'm thinking of using the OEM Pad/aftermarket rotor kit from British Atlantic.. I can upgrade to the OEM rotors but I'm wondering if its worth it? Everything on this truck is factory and I like the feel of the stock pads. OEM rotors worth the cost?
Thanks
Old Jun 12, 2013 | 08:55 AM
drowssap's Avatar
I would suggest using Akebono ceramic pad, because they do not throw less dust. lest brake dust means less ABS problems. But every one had there own opinion.
Old Jun 12, 2013 | 09:26 AM
Dan7's Avatar
If you're looking for better stopping power, not worth it. If you're looking for longer lasting rotors, worth it.
Old Jun 12, 2013 | 09:44 AM
teeboli's Avatar
thanks yes standard stopping power is good for me and I have 80 on the stock rotors so I may just pay up for the OEM version.. Thanks!
Old Jun 12, 2013 | 10:16 AM
The Akebono pads are the best thing on the market for a D2, they stop better, no dust, no squeaking don't upset the ABS and last longer then most others.
Both e-bay and amazon have the pads for the best price,
EUR 676 pads for the front and EUR 493's for the rear.
They well on the solid rotors and better on the slotted and drilled.
Make sure to do a full 2 quart DOT 4 brake flush when done.
Old Jun 12, 2013 | 12:18 PM
crypticbcd's Avatar
4th Gear
I placed an order for my Akebono pads today.
What are the part numbers for the DBA gold series rear rotors? (2004 Land Rover Discovery)
Old Jun 12, 2013 | 03:00 PM
0304Disco's Avatar
I just replace my front and back rotors with EBC OEM spec and Akebono pads for $315.00 total.
This place has probably the best prices I've seen.
Old Jun 12, 2013 | 03:56 PM
DBA is not making them any more, but, British Parts of Utah as the next best slotted and drilled rotors they are made in the UK.
If you are not aware, slotted and drilled are better then the EBC because they actually vent the hot gases from between the brake pad and the rotor, dimples don't doo anything.
Old Jun 15, 2013 | 09:24 AM
crypticbcd's Avatar
4th Gear
Thank you for the prompt response, Disco Mike!!
I know that DBA no longer makes them. I was merely asking if anyone knew the part numbers. You can still find them on various websites - most of which are overpriced now that DBA stopped making them - so I want to ensure that I order the correct rotors before cleaning out my wallet.
I will check out the British Parts of Utah rotors as well. <--- thanks for the back-up plan!
Old Jun 15, 2013 | 09:36 AM
Disco_Fever's Avatar
I run powerslot rotors and hawk pads. Noticeable difference, and have been very pleased with the rotor/pad combo on many cars- including Lexus LX 470, Lexus IS 300, Lexus GS 430. I've read of people running that setup on F-150/250 trucks and all manner of sports cars as well.
tasr12
Dec 17, 2009 01:17 PM
Galaxie_406
Jan 5, 2009 07:03 PM
phidelt583
Dec 8, 2008 12:36 AM
stefan
Jul 8, 2005 08:46 PM
