brake fluid leak - master cyl or reservoir?
Old Jan 10, 2017 | 02:48 PM
ge234's Avatar
Default brake fluid leak - master cyl or reservoir?
hey guys, i am in a pickle. brake fluid leak from the reservoir/master cylinder area is getting worse, most likely because of the extreme cold shrinking the already bad seals and gaskets. i've read about some quick fixes involving compressing the reservoir onto the master with zipties to further crush the gaskets. i'll try this tonight to stop the bleeding but this is a daily driver my wife uses for the kids...meaning i want to get it right. should i take it to carlos in the bronx for new parts? is there someone on long island i should take it to?
Old Jan 10, 2017 | 03:45 PM
LR03NJ's Avatar
If you and siphon or drain it first to eliminate contamination on the epoxy. Then dry clean with alcohol, use JB weld 2 parts. then tie the zip. That might work.
Old Jan 10, 2017 | 05:40 PM
PalmettoDisco's Avatar
You can order new grommets here:
https://www.powerbrakes.com.au/shop/...0be1e9e495da5?
It is in Australia, so shipping time and cost will be relatively high, however, Aussie dollar is cheap on the dollar. The 21.80 Aussie price is less than $16 US. Our D2 is their D4, notice production years.
Old Jan 11, 2017 | 12:13 AM
number9's Avatar
Seals or a new reservoir kit, PN STC2904 will like stop your leak.
Genuine Land Rover Brake Master Cylinder Reservoir Repair Kit Discovery I 94-99 | eBay
SolAeon
Jul 10, 2012 09:05 AM
Cosmic88
Dec 13, 2010 08:25 PM
jneil
May 25, 2010 09:31 AM
