Brake fluid under ABS unit after replacing SVS seal
Old Nov 8, 2022 | 09:53 AM
Droog's Avatar
4wd High
Default Brake fluid under ABS unit after replacing SVS seal
I'm wondering if anyone else has run into this issue or might know what could be causing it because I'm stumped.
I purchased the shuttle valve seal kit from Falconworks as I was already replacing the modulator switch and I could tell there was a small leak happening over time because the coating on switch wires was starting to break down. After doing that and then bleeding the brake system, I am now getting a very noticeable leak of brake fluid from the valves that is pooling underneath the ABS unit (picture attached). I know these are prone to leak, but never this much. I've taken it all apart again and inspected the valves and put new seals in and I'm still getting a leak, even before bleeding the brakes.
Any idea what could be causing this? Hoping I don't need to get a new ABS unit as it was not leaking this severely before.
Old Nov 8, 2022 | 03:25 PM
matt3502's Avatar
Not trying to be a wiseass, but are you sure all your brake line fittings are tight? Any chance that when you moved the whole ABS block to get at the modulator you cracked a brake line?
Old Nov 8, 2022 | 04:30 PM
Droog's Avatar
4wd High
Well I just replaced all the lines and pipes as well so those are all fine and torqued down. I can't see any brake fluid originating from the fittings, and when I took off the ABS unit the first time to figure out where the leak was coming from its pretty evident it's coming from one of the shuttle valves (as seen in the photo)
H Hill
Oct 19, 2021 08:51 PM
Black Dynamite
Jul 4, 2021 07:07 AM
Davis31052
Jun 30, 2020 09:42 AM
redrover75
Oct 8, 2014 08:26 AM
JAC
Feb 27, 2011 01:21 PM
