Brake Help.
Brake Help.
I am attempting to bleed the brakes. I have the quatro amigo lights going and and fixing to have the codes run again. I have done the Option B process. Cleared codes and they stayed off for a little more than a day.
My problem is that when jumping the ABS relay, the RF and LR brakes bleed just fine. The LF and the RR do not pressure up. Same thing when you perform a pedal bleed as well. The lines a clear. I blew them out, but they still fail to pressure up.
What could be causing this?
I will update with codes shortly.
I order a code reader so I won't have to keep running down to the mechanic.
Here are the ABS codes from a Snap-on scanner
9-ECU Ground or Reference Ground Fault
72-Shuttle Valve Switch Long Term Failure
76-ECU Ground or Reference Ground Fault
87-Pump Relay (Open Circuit)
112-Rear Right Outlet Valve (Internal Supply)
Also showing code P0455 Evaporative Emission System Leak Detected (gross leak / no flow)
Any ideas ideas are appreciated.
mollusc (01-31-2022)
