Brake Help.
Old Jan 30, 2022 | 04:07 PM
drgunney's Avatar
3rd Gear
Default Brake Help.
I am attempting to bleed the brakes. I have the quatro amigo lights going and and fixing to have the codes run again. I have done the Option B process. Cleared codes and they stayed off for a little more than a day.
My problem is that when jumping the ABS relay, the RF and LR brakes bleed just fine. The LF and the RR do not pressure up. Same thing when you perform a pedal bleed as well. The lines a clear. I blew them out, but they still fail to pressure up.
What could be causing this?
I will update with codes shortly.
I order a code reader so I won't have to keep running down to the mechanic.
Old Jan 30, 2022 | 06:27 PM
drgunney's Avatar
3rd Gear
Here are the ABS codes from a Snap-on scanner
9-ECU Ground or Reference Ground Fault
72-Shuttle Valve Switch Long Term Failure
76-ECU Ground or Reference Ground Fault
87-Pump Relay (Open Circuit)
112-Rear Right Outlet Valve (Internal Supply)
Also showing code P0455 Evaporative Emission System Leak Detected (gross leak / no flow)
Any ideas ideas are appreciated.
Old Jan 30, 2022 | 09:09 PM
Best4x4's Avatar
Did you clear the codes after Option B? Did you re-use your original Shuttle Valve Switches? Did you leave the OEM black plug on the Shuttle Valve Switches or did you cut it out of the loop and connect it to the 2 wire trailer harness?
Old Jan 31, 2022 | 08:43 AM
drgunney's Avatar
3rd Gear
I did clear all codes, they stayed clear for about 3 days. I did re-use the original shuttle valve. I cut the OEM black lug out.
lilherc
Jun 7, 2019 08:51 PM
jfall
Nov 23, 2016 05:17 PM
Bishop
Nov 23, 2015 06:36 AM
bostongrun
Oct 30, 2015 11:33 AM
mbeasom
May 23, 2011 03:53 PM
