Brake Hose Jump Brackets
Old Jun 22, 2020 | 12:01 PM
mhardt's Avatar
Default Brake Hose Jump Brackets
This weekend I tackled putting in a whole new brake system. The parts had been piling up in the garage over the past few months. The process was a success...except for two issues;
1) The two brake hose jump brackets on the right front are beyond repair; both brackets were fully and utterly rusted out. The upper forward bracket (SHU100300) is no longer made. I cannot find a part number for the second bracket that is riveted to the chassis. See attached drawing; parts #6 and #7 (with rivet
Diagram of brake hose jump brackets (and rivet?)
2004 LR D2 driver side brake hose jump brackets in poor shape.
2004 LR D2; front driver side brake hose jump brackets in poor shape.
#9?) Does anyone know where to find the brackets? And, how is the best way to attach the second lower bracket to the chassis; is there a special rivet; size, material, etc.
2) How do you thread the rear right brake hose into place? I pulled what was left of the original pipe and it came apart in three pieces. The left side was easy; just snaked it straight along the chassis. The right rear pipe cuts across at the rear crossmember and then down the rest of the way on the opposite side rail. Any tips or tricks would be greatly appreciated.
Thank you, thank you.
Cheers,
Mike
Old Nov 18, 2024 | 02:16 PM
Gazdisco2's Avatar
Hi Mike I know it's been awhile since you posted about the brake jump pipe brackets but did you mange to sort any out?
I'm now in the same position. I have the part numbers but they are both obsolete and struggling to find replacements.
Thanks
Gareth
techniq808
Sep 9, 2015 11:31 AM
JasonjCook
Sep 30, 2012 05:58 PM
starcraft
May 11, 2009 02:20 PM
tomfraser
Dec 2, 2008 10:17 AM
danepeople
Oct 17, 2006 10:10 AM
