brake light bulb mystery
Old Feb 11, 2007 | 08:08 PM
chrisusvi's Avatar
Default brake light bulb mystery
I noticed on my 97 Disco 1 that there are two bulbs (top and bottom) in the brake light, reverse and signal assembly, NOT the brake lights on the bumper.
The bottom 2 bulbs on driver and passenger side of the assembly do not light up when the brake are applied. I changed the bulbs and still doesn't light up. Nothing happens.
The top brake lights in the assembly light up fine, but the bottom ones don't. All other bulbs in the assembly work fine, but the bottom 2. Are they connected on the same circuit? Is it supposed to light up at all? There is a bulb in there, so I assume that it is a brake light bulb.
Any ideas what could be the problem?
Thanks for any input.
Old Feb 12, 2007 | 11:32 AM
Cirrus's Avatar
Default RE: brake light bulb mystery
Hey,
The bulbs that you are talking about are for the "rear fog lights". There is a switch to the left of the speedo. It looks like a rear defroster switch. The switch will only light up when the headlights are turn on. Then the switch is depressed,the lights on the bottom will light up. I hope it helps.You can also look this up in your owners manual.
kpl1228
Feb 19, 2012 07:33 AM
RROJ
May 5, 2011 12:43 PM
jimbucky30
Apr 24, 2011 09:10 PM
Classklown90
Aug 21, 2010 07:24 PM
bavarian_range89
Dec 29, 2007 02:56 AM
