Brake lights do not work...
Old Apr 2, 2010 | 01:28 PM
grussell's Avatar
Default Brake lights do not work...
I checked the bulbs-good, checked the fuse-good, checked the brake light switch-appears good. The tail lights, blinkers, headlights all work. Any ideas?
Old Apr 2, 2010 | 03:02 PM
kenk's Avatar
Relay(if there even is one)?
Old Apr 2, 2010 | 03:47 PM
greg409's Avatar
Mine was a poor connection in the bulb holders, gave me fits, I've got jumpseats in the way.
Did you remove the fuse & look at it? (mine looked good in the fuse panel with flashlight, but was blown.)
Did you check for 12v @ bulb socket?
luck,greg
Old Apr 2, 2010 | 04:03 PM
grussell's Avatar
Removed cruise control switch and tested it-good, put it back on and brake lights are working. Hmmmm
Old Apr 5, 2010 | 09:47 AM
okdiscoguy's Avatar
order a new brake light switch and keep a spare in the truck. if it quits, you will be stuck.
Also, you can test the lights by putting jumper wires from your defrost onto the third brake light. The traces are all on your rear window. This will also get you out of park if you are stuck.
Snowdog
Apr 7, 2016 01:05 PM
USMC_Denver
May 8, 2009 12:41 PM
klh113
Dec 17, 2007 02:13 PM
