Brake Lights Turn Orange?!
Old Apr 18, 2018 | 11:38 PM
No Doubt's Avatar
Talking Brake Lights Turn Orange?!
This is weird.
Start the Disco.
Turn on headlights.
High tail lights are red.
Hit the brake pedal.
Left brake light comes on red.
Right orange blinker turns solid. No right (high) brake light.
Anyone ever see this condition before?!
Old Apr 19, 2018 | 09:39 AM
Twix's Avatar
Sounds like someone wired a new connector and got it wrong
Old Apr 19, 2018 | 05:02 PM
No Doubt's Avatar
Solved it!
In the rear passenger corner pillar behind the plastic trim is a white electrical connector that slips onto a ground pole, with a ground wire that has a captured nut that screws onto the ground pole to hold that white connector on.
Well, that nut had come off, its ground wire was loose, and the white electrical connector had slipped off of that ground pole.
Slipped the white connector back onto that little pole, then put the captured ground wire nut on top and tightened.
Problem solved!
Brake lights and blinkers now work normally again.
Old Apr 19, 2018 | 06:52 PM
JUKE179r's Avatar
Thanks for your follow up to your problem in order to help others.
Dv8er
Mar 11, 2017 12:26 AM
youngbro401
Dec 26, 2008 06:24 PM
angasreid
Oct 14, 2006 06:45 PM
georgery
Freelander
Nov 7, 2005 02:26 PM
