Brake lights unequal brightness
Old Jul 8, 2022 | 03:56 PM
cappedup's Avatar
Default Brake lights unequal brightness
My left brake light is dimmer than the right. They both illuminate.
The tail light part is fine. Just when pressing the brake one glows more. Changing the bulb makes no difference.
Any ideas what thats about?
Old Jul 8, 2022 | 04:14 PM
jastutte's Avatar
coincidentally enough, one of my '04s does the same thing on the left tail light.
i think it's an issue with the lens itself. good luck finding a replacement. they are NLA new, as far as i know and get snapped up pretty quickly used.
Old Jul 8, 2022 | 04:55 PM
mln01's Avatar
You might try removing the dimmer bulb to check voltage at the socket. There was a rusty lamp socket on my truck many years ago. I don't now recall which light it was, but a rusty socket could prevent the bulb from being as bright as it should be.
Old Jul 8, 2022 | 05:52 PM
OCMike's Avatar
My 04 does this also. Driver side is dimmer that passenger side.
Old Jul 8, 2022 | 06:46 PM
cappedup's Avatar
I hadn’t thought of the actual lens being the issue. Easy check. if it’s just dirty I’ll kick myself.
I’ll check the voltages.
Old Jul 8, 2022 | 06:48 PM
cappedup's Avatar
hmm. That’s three of us. We should start a group. Oh wait.. we are in one
Old Jul 11, 2022 | 07:27 PM
cappedup's Avatar
Pulled the lenses off for the 1000th time to clean the contacts. Lenses are in equal condition.
Checked the voltages which match each side.
Then by a miracle they were equal brightness. So maybe the contacts looked clean but weren’t.
I’ll monitor and report back if they switch back to unequal again.
Old Jul 24, 2022 | 01:42 PM
Kasey King's Avatar
Default Check the bulb orientation
I installed new brake light bulbs and had the same issue. Thought it was a voltage issue, turned out that I installed the bulbs incorrectly.
The brake bulbs are dual filament, one dim, one bright. When you’re running with lights on, the dim ones should light light up, the brighter filament illuminates when you hit the brakes.
dougn
Mar 10, 2023 04:40 PM
gallaways
Mar 7, 2023 01:57 PM
jaystekan
Nov 10, 2014 11:06 PM
keithlarue
Dec 5, 2013 06:43 AM
