Brake line/ bleed question
Old Feb 24, 2009 | 08:45 PM
Jupiter Rover's Avatar
Default Brake line/ bleed question
I just got done installing some rears spacers on my discovery. But, I had trouble with the passenger spring getting back in with the spacer so I disconnected the brake line from the caliper and I lost about 3/4 or so of a cup of fluid.
Do I just re-attach the brake line and top off the reservoir with fluid and bleed only that brake? (I rented a fancy brake bleed kit from advance auto)
Or do I have to change all the fluid and bleed all 4 brakes.
Thanks.
Old Feb 24, 2009 | 09:39 PM
roverguy7's Avatar
do the whole system while youre at it. let it gravity bleed from the one you had disconnected til you get a steady drip, then use the vac to suck it out til you have clean fluid comming out, repeat for all wheels... order matters, RR, LR, FR, FL
Old Feb 24, 2009 | 10:10 PM
AK Rover's Avatar
If it has been a while since you have flushed the whole system go ahead and do it while you have the brake bleeder. If the brakes were flushed recently, within the past year, you can get away with just bleeding that one brake.
according to the RAVE manual and contrary to everything most of us know about bleeding brakes, the correct bleeding order for a Rover is RF, LF, RR, LR.
Old Feb 24, 2009 | 10:25 PM
I just had the 60K mile service done. I'll check the papers to see if they did the brakes. Pretty sure they should have.
If they didn't touch the fluid I'll drain/refil.
Thanks for the help guys.
Old Feb 25, 2009 | 09:39 AM
AK,
That is just one of many errors printed on the Rave CD, should start at the r/r, l/r, r/f and left front, apx. 3 pints of DOT 4.
Pete, Rebleed your brakes, the dealer will never do a full bleed. Quick way to varify would see how many pints you were billed for or see if you brake fluid is crystal clear, if not redo it.
Old Feb 25, 2009 | 01:36 PM
Originally Posted by Disco Mike
AK,
Will do.
Ah, so the RAVE is wrong. I'll make a note of that. Crystal clear it is. Thanks.
Old Feb 25, 2009 | 03:09 PM
AK Rover's Avatar
AK,
I'm pretty sure we have covered this before now that you mention it. Must have been outside my 20 second memory.
Old Feb 25, 2009 | 03:29 PM
jycsalas's Avatar
I questioned Disco Mike about the brake sequence when i was doing my 60k service a few months ago, but he set me straight! Do as HE says, i have great brake response and you can barely see my brake fluid unless you shake the car.
But I think I still have stock rotors and pads...a few more months and those will be changed. =)
Old Feb 27, 2009 | 12:57 PM
jrkstore43's Avatar
Has anyone used a Motive Power Bleeder for bleeding brakes?:
http://store.motiveproducts.com/shar...unt2=988944649
Would this model work on a 2003 LR Disco II?
Thanks!
Old Feb 27, 2009 | 01:04 PM
discoxd's Avatar
the reason for the bleed order mike posted, as best i can figure, is that you work from the brake that is furthest away from the reservoir first... which makes sense... the farther you are from the reservoir the more space you have to contain air...
RoadDog
Jun 6, 2015 07:26 AM
DSCVRY
Dec 1, 2014 07:18 AM
innzane
Jun 21, 2012 10:07 PM
JerrodSteph
Jun 12, 2011 06:04 PM
JavaDiscoII
May 29, 2010 04:33 PM
