Brake Master Cylinder & P1590
Would anyone know if a failing Brake MC can or would cause error code P1590 (three amigos)?
My Disco has been recently showing signs of a very very weak brake pedal. I suspected air in the lines and bled them, ran hill decent, and bled again without any improovement. With that said it leads me to believe the MC is going bad.
Also recently had the front passenger side hub worked on at a local shop because the tire shop stripped a wheel stud. I didn't have any codes for a few days after the work was done so Im not sure which scenario above might have caused the current code and three amigos.
Unfortunately I don't have an advanced LR scanner tool to see which wheel is giving me the ABS error if that is indeed the cause.
Any feedback or how to troubleshoot would be appreciated.
