Brake Problem - Long Pedal Travel
The brakes on my daughter's 2001 Disco II have deteriorated recently. When started and moving down the road the first pedal push goes close to the floor before the brakes engage. On the second pedal pump the brakes come up much closer to normal , but then the cycle repeats next time the pedal,is pushed (after some additional,driving). I bled the brakes from furthest to closest with no real change in the long pedal travel. With engine off, brakes pump up solid and stay there so master cylinder okay? With engine off, pumped up brakes and held them and started the engine, brake pedal moves close to the floor so booster okay? Checked the pads and all are still good thickness. What am I missing? Thanks.
parks
Jan 31, 2005 12:21 PM
